New Clouds are available in [Corona 9 Daily Build](https://forum.corona-renderer.com/ Chaos Corona 9 for 3ds Max - Daily Builds Changelog #msg202433)!
Check them out in CoronaSky and share your results!
P.S. Thanks Maru for the renders!
By the way, did I understand correctly that cirrus clouds cannot be randomized?
Feature request: it would be nice to have cloud shadows as optional - sometimes you set the lighting and you don’t want it to change, but you want to have few clouds in the sky without affecting anything else in the scene. I find cloud shadows quite a hit and miss, especially since they act so unpredictably in IR.
Do they cast occlusion shadows? Something that HDRi bitmap that looks visually the same does not? Or you mean all lighting in general such as brighter white cloud contributing bit of additional light.
They actually do, at least i think so. Sometimes it looks weird when shadows from the sun and the clouds are kinda mixing together and often they’re simply annoying, when you move the sun and the shadows pops in and out constantly and worst of all that you can’t trust IR - sometimes you get cloud shadows, but if you restart IR they disappear, or IR and regular rendering gives different result. I’m sure most of these issues will be ironed out, but having an option to opt out of cloud shadows, can’t hurt i think.
I can imagine..
Not sure if shadows from clouds are even good idea if the sun (and light from sun) is never occluded or modified by the clouds itself. We don’t get occlusion shadows from HDRi either for logical reason (no actual physical object at certain distance).
But hopefully the clouds will always contribute to the overall light &reflection in form of Skylight. I.e, act like HDRi.
Yes, they do contribute to overall lighting. Not sure how accurate it is, but it looks quite nice. By the way, i was impressed to find that shadows are visible in viewport and they are pretty accurate to what you get in rendering, so in theory you don’t even need to launch IR to set-up them :]
Looking nice! Did you adjust contrast significantly? Your clouds looks much more punchy than what i usually get.
/prompt “highly detailed clouds over a stormy sky”, in the style of renaissance painting, earthly tones
looks great! ![]()
I’ve noticed even with the ACES on, I get some “sad no contrasted” results on the sky. The cloud model is cool but as you wrote I need to add additional contrast to the image.
But from the other side, if I think about it, when I take a photo with my DSLR in RAW format, I need to work all the data in Lightroom. At this point I prefer keeping the ACES option on, not apply any LUT and do the work manually in Lightroom as always.
Just my thoughts…
I would like request to expose random seed parameter in clouds UI. Offset is good for animating cloud movement, but it kinda sucks for fast exploring of different clouds positions, since you need to drag the spinners a lot, or enter numeric values by hand to get substantially different clouds.
+1
Thanks, reporting it for further consideration.
(Internal ID=959574428)
Nope other than making sure it’s the PRG Sky, and that you have no overrides for direct visibility etc. or LightMix layers with multiple skies that could mean you are looking at a different sky ![]()
Oh and make sure your sky altitude and camera actual altitude in the 3D scene is not higher than the Clouds altitude.
Nope. Nothing.
I’m sending the file attached just in case the devs want to see it.
But, unless I’m missing something, it’s not showing the clouds at all.
temp01.max (928 KB)
