For some reason my clr threshold or my noise threshold will not let me change them to the desired setting. I am trying to put my clr threshold on .005 and my noise threshold to .01 but everytime i do that it goes right back to 0
after trying to mess it with it more, it seems the lowest my sample size in my light cache,Noise threshold and clr threshold and will go is .1
guys I’m not trying to be a pest, but im on a little bit of a deadline here and could use some help, I’ve tried reinstalling vray and that didnt work either. Thanks so much for any help
Hi, Billabong,
i’ve had this kind of problem.
i think you can solve it in max preferences : general tab : decimal precisions. with 3 (or 4) digit precision you can specify your values in vray render panel.
Hope it helps.
That was it!!! Thank you so much Jerome
you’re welcome !
i wish you’ll respect your deadline.
Have a good work !
well now if I could only get treestrom to start acting right I would be doing ok, but hey thats another story. thanks again
