CMYK warning
would it be possible to add a CMYK warning when vray finds out that the map is using texture in CMYK format?
Problem is that vray has no problem rendering it locally, but if you render it over thebackburner you receive an error sooner or later in the render and the render has to start all over again :-/
Best Regards
Martin
i always thought max didnt like cmyk
:slight_smile: you get a warning on a 12GB render node that max doesnt have enough memory to create filter table (or something like that).
Mind you that the map has only 1 MB :)))) and is rather small.
Strange is that the texture render but some of the elements from the texture are missing.
Imagine you have a flattened JPEG poster with some graphics on (picture, logos and text)…it will take out some of the elements…ususally things in grey :slight_smile: really weird
