Here is my C4D corona coin model - there is baked and unbaked versions.
With the unbaked version user can test that does Projection work correctly with displacements and with baked coin you can test that what it should look like in Corona.
-Kind regards, Juha Mukari
And sorry if this is wrong place to post this kind of topics.
EDIT: I added scene with xpresso breaking tag (break object when it collides to the floor)
(at the moment in my C4D this scene will crash when user try to render the animation)
The version which I have at the moment and which have bug with displacement rendering:
Build timestamp: Oct 2 2014 13:23:47
Version: A1.1 (core Daily build post-A7)
Cinema version: R14.042 (built for R14)
Plugin status: initialized successfully
EDIT: I edited the scene (this time it has bump map ON by default, and displacement is set OFF, you can turn ON the displacement by your self, but remember turn bump OFF if you use Displacement…)
EDIT: it looks like Corona crash even when I use bumpmap only
You can also test motion blur with baked animation.
Ok.. So I have been tired so I didn’t noticed that it has wrong scale in thickness - fixed.
Also new scene builded with new xpresso trigger for turning dynamics and visibility.
EDIT:
New file: “COIN-break_fixed” includes new polygon selections for materials, this time the materials
go direct line in the edges of the coin pieces. Also some improvements for collision (pieces do not go through
anymore)
EDIT: New “new_fix_coin_break”, second try to make pieces stay on floor (pieces do not go through).
here is demo video from new scene… Just waiting Corona bug fixes so I can render this scene.
EDIT: New xpresso breaking file, better way to break objects. coin_size_fix.zip (4.4 MB)
