…and thought YES! then i read the heading ‘wishlist’, and thought NO!
anyone else frustrated by the scene explorer and it’s great potential for overview, yet it’s complete lack of overview due to such a simple thing as collapsing hierachies?
or more interesting, anyone so frustrated that they found a solution?
Make sure Max isn’t running
Make sure you have hidden files turned on
Go to the following path:
XP 32 bits: C:\Documents and Settings\<username>\Local Settings\Application Data\Autodesk\3dsmax\<version> - 32bit\enu\defaults\MAX
XP 64 bits: C:\Documents and Settings\<username>\Local Settings\Application Data\Autodesk\3dsmax\<version> - 64bit\enu\defaults\MAX
Vista 32 bits: C:\Users\<username>\AppData\Local\Autodesk\3dsmax\<version> - 32bit\enu\defaults\MAX\
Vista 64 bits: C:\Users\<username>\AppData\Local\Autodesk\3dsmax\<version> - 64bit\enu\defaults\MAX\
Open CurrentDefaults.ini
Replace SelectByNameUsesSceneExplorer=1 with SelectByNameUsesSceneExplorer=0 (bottom of the file)
Save and run Max.
although, i think you are mixing up the scene selector and the scene explorer
if i remember correctly, the old scene selector didn’t even have any hierarchies to collapse/expand, no? that feature is actually ok, i just wish there was some more controls for it…
I probably just used the wrong name, but it’s the same thing. The window that pops up when you press the “H” key
What annoyed me the most was the everything was always expanded, and not arranged by name. And no matter how many times you click the Name bar, it would always reset once you closed it.
it is actually two different explorers, there’s the ‘H’ thing, and the one that i am talking about up in the tools menu under ‘new/manage scene explorer’ option
the one in the tools menu can also be sync’ed with viewports which is kind of nice
