Case: Glas on white background does not separates well from it. So a little exposure correction solves this problem (glas gets a tiny little bit darker). This does not translate into the alpha chanel. Bummer. Here the luminance value should go up a bit as well. Other way: glas gets less transparent.
It would be great having something like an “effects results chanel” for alpha in the vray buffer for a multichanel exr workflow. Or if the “value” corrections in RGB would transfer to alpha as well.
Submitted on AHA Ideas (VRAYMAX-I-127).
