color banding
i have problem with displacement here.
i’am rendering a Zdepth from an object in max, wich i’am using as displacement map for a plane. cause the client want an emboss-like effect from that object.
but when i render out the Vray-zdepht, i get color banding in it, wich is visible in displacement.
i don’t know if its really a Vray Problem. cause i get same with MR and scanline.
in vray and MR its circular, and in scanline its horizontal…
i try’d to render out a 32bit floating point, but same result.
here is a example what its look like:
does anybody an idea how to avoid this?
i try’d to blur in PS. but no luck. when blur in max the edges getting unsharp too of course wich i don’t want…
any ideas?
thanks in advance and best regards
Jonas
try to put a relax modifier on it?
You need to use a 16-bit output image format (e.g. PNG), or floating-point (e.g. OpenEXR).
hi Vlado,
i try’d to render out as .exr 32bit floating point.
but was same result…
How did you produce the .exr?
i’ve renderd out a vrimg, and converted it to .exr
no stop, sorry.
i’ve try’d it this way, but i was too stupid.
i’ve said “split render channels” and saved zdepht as 32 bit exr seperately.
No idea then; perhaps you can try to play with the min/max zdepth settings to increase the precision of the file.
ha,ok. stop again. sorry i’ve render again an exr. it seems to work..
i dunno why. but it works. displacement map is 400MB. but it works :slight_smile:
