color bleeding
hi
this is realy great fourm
i wanted to ask about the way to remove color bleeding
when i use a floor material like the VRayOverrideMtl in vray
Can you give more info?
What you get in VFB. What kind of material on the floor
Maybe you got strong color bleeding in your scene because your bitmap in floor material has more saturation than it must be
i found it
CoronaRaySwitchTex
solved
headoff i was having trouble in the floor color
when i use green color for the ground the room became green and also the other colors
in vray i use the overrite mat
now i found CoronaRaySwitchTex and the problem solved
sorry for my bad english
and thanks
Uwelcome! (;
But if you will use a right value of albedo in future you won’t get any problems with color bleeding
