color bleeding
is there a way to decrease the color bleeding in the scene without altering the send GI values of a certain material?
In finalrender I had a saturation value that I could use for this puprpose (it’s not the same as changing the saturation in PS or something)
Does vray have an easy parameter for this?
thanks,
flipside
There have been several threads about his in the past. Last I remember there was to be a saturation control added in a future build.
At the moment keeping the secondary strength around .5 helps.
Another method is to run the light solution with light colors then render using rich or more saturated colors. This trick works in fR as well.
Thanks, I’ll keep it in mind!
But I don’t think I will use finalrender again :slight_smile:
So definitly you have fliped for this side? Just kidding :smile:
Gonçalo
I would flip sides if it were for this forum alone! Man I love it, this is almost a chatbox instead of a forum, so quick replies always!
:wink:
GoncaloP just don’t disappear man - you are a real help to everyone !! :wink:
