OK - I am looking for a good solution to calibrate a few of our monitors to our new HP color printer. Is it possible to get a good hardware calibration device with software for about 5 or 600 dollars that will build profiles for using photoshop? I am looking for the best cost effective solution.
We are haveing a terrible time getting prints to match gamma corrected screens without doing a lot of expensive test printing!
If you buy a spider, buy the pro version, or you’re screwed. It doesn’t work on dual monitors either, as it seems windows cannot assign 2 different profiles to two different monitors on one graphics card. So you’ll need two cards also.
jujubee…What do you mean screws up lut? What is lut and how do I use it? I noticed that it resides in the gamma settings of max 8…I dunno how to use that.?
Betweeen the two products listed so far in this post…Which one is the top shelf? I only want to make this purchase one time. Also, how does this affect LFW?
I have MonacoOPTIX for 2 years but now it refuses to work with my new EIZO CG210 so I got Eye-one II from gretagmacbeth.
It works great. But color profile for monitor is just a part of the bussines - you need to have a color profile for your printer as well.
Most pro printers have a set of ICC for different media, same for a paper manufacture - they can have ICC for your printer.
Here some Soft Proofing BasicsDVD Talk Forum
I’ve actually gotten great results just by using Adobe Gamma (see my tutorial here:http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=15253&sid=376867665a5602e4f5ec040883a33cb9). My prints match my monitor almost exactly. Even though I have access to an Eye One, I prefer the quick and easiness of Adobe Gamma. I have the Monitor Calibration Target as my monitor background image and do a visual test every day.
On three separate Nvidia cards I have, I’ve installed the Spider system and upgraded to the Pro version to see if I could get it to work. All the times I’ve tried it, I get an error message saying that it had problems ‘writing to the LUT’ and it wouldn’t work. Three separate computers, three separate monitors, three separate cards.
I tried extensive searches on the web, as well as calling up their technical support to see if they were aware of any issues. The problem was never solved so I returned it.
Overall, I’ve had pretty good luck with Adobe Gamma in conjunction with some of the methods listed in the Linear Workflow methods. You can’t use the single gray target but the RGB ones and sit back at a distance. My prints almost always turn out spot-on when an image is converted to CMYK.
On the more target line “Monitor Calibration Wizard” is the best software calibrator i have used, it has 8 targets for each of RGB. It gives some really good results.
“You can’t use the single gray target but the RGB ones and sit back at a distance.”
Gray/grey - when you launch Adobe gamme it gives you two options if you use the Adobe Wizard - one grey box with horizontal lines - if you check the checkbox there there’s an option to adjust the three colors (RGB) separately which gives you significantly more control.
As you adjust the color sliders, sit back and slide them until the middle boxes blend together with their surrounding colors. Repeat on each one. Sometimes it helps to squint also.
I also make my desktop black with the following picture centered. I reference both the Adobe Gamma boxes and this image while I am calibrating. The image below should become almost perfect grayscale if your monitor is balanced correctly - otherwise you will see RGB values:
Cool! Interested in checking it out thanks.
O.k. I purchased the whole suite. I have a new 21" DELL flat screen.
Now what? After reading Vlado’s Linear workflow tut…He suggests using method III. Which entails this group of suggestions:
-Calibrate monitor for linear output using (1.0 gamma)
What white point value should I use?
-Disable gamma correction in 3DSMAX.
This is only done in one place right? Through preferences of viewports right?
-Make sure textures are NOT Gamma corrected
-Do NOT apply gamma correction to rendered result.
I assuming he means through the VRAY vfb right?
What about the settings in the color mapping tab of VRAY’s rendering settings? What do I need to set here?
This is really hard for me as I need to make material changes to a clients model that was done with a non-calibrated CRT. Now my scene is totally blown out!
