Color Code by Revit Workset
Status: declined
Visualizing Worksharing Display Settings allows Enscape user to quickly and easily navigate design in Revit and determine if model elements are assigned to incorrect workset.
Image 01 is default Revit sample file with Worksets enabled. Each wall has assigned a unique workset.
Selecting Worksharing Display Settings (Image 02) will color code model geometry by Workset assignment.
Image 03 is result of enabling Worksharing Display Settings
Submitted on AHA Ideas (ENSCAPE-I-1594).
Hi Phil,
Could you please elaborate your request? We assume that you want this color coded visual output is reflected on Revit side, is this correct?
If so, could you tell us a bit more about how having this in Enscape would benefit users? We’re interested in learning what problem this would solve and how it would improve the workflow. Thank you!
Submitted on AHA Ideas.
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
