is there a way to wrap a multi/sub-object in a color correct material? I would like to avoid having to go into each material to de-saturated my colors.
I asked about this in another thread too. No answers there so my guess is no. It would be extremely handy though.
b
A non perfect solution is to use a composite material and blend the base material with a mid grey material over it.
The bad thing of this solution is that the grey material blend also the reflections and bump and the other material details.
You actually want to desaturate your diffuse color, right? have a look at this scene:
6 objects with different object ids, 6 materials, 1 instanced multi-subtex wrapped in a color correction map.
Hope this helps.
Greets Ben
Thanks Ben - that method is workable in many cases and is how I do it now usually, but often what is needed is more complex (colour tinted reflections, complex blending of materials that dont’ use multi-sub tex) so having the ability to colour correct the *net* result of a material would be the goal. It would just be far simpler/faster that way - and less prone to user error ![]()
/b
For RGB this is rather easy technically speaking (on the SDK side). I wonder why nothing exists hehe. Have not looked into propagating the corrections into elements tho.
Regards,
Thorsten
Thanks, I’ll check it out. I guess we could de-saturate the whole scene in v-ray, or in post, but I would like to control each object.
