When I use a color correction node (diffuse), Vantage will show the corrections. But when the object is behind a refractive object and with a refraction glossiness of less than 1, the color correction is ignored (see attached).
If you switch to “Advanced” in the render options, there is one called “Shading graph for glossy/GI”
Thank you, that’s sorted it!
