Color Difference between final render and material override
I have an urgent issue with color of the element. In frame buffer with material override my walls color looks like normal as I want, I except the wall from clay material, but in normal mod with all textures the walls look like darker. I didint change any material setting between this two mod
https://imgtr.ee/images/2024/07/12/8e94299e3bbe6c16bcac9ddfd73f0a24.png
https://imgtr.ee/images/2024/07/12/9b0aacded9fb436828e80f83120947b9.png
I need the brighter one, please helpp
Since Corona simulates real life rules of light transport, there are these things called “reflections” and “global illumination” in it. If you render a dark wall surrounded by dark objects, it will look different than the same dark wall surrounded by bright objects.
