color difference in render with vray in 3ds max 2018
Hello Team,
I am facing an issue in vray render with 3ds max 2018.
some color difference in there in render. Like blue color becomes purple.I tried turning on linear workflow in color mapping settings of vray.
I found that color comes fine in render but texture changes. and some dullness applied.
I have attached images. You can see the difference.
Please help me with color difference problem.
There is no image that i can see.
In any event, if you think it’s due to V-Ray, you’re better off sending a scene (or the offending part thereof) to our support.
Hi Lele,
There was some error while i was posting this query. So, my images did not get attached.
Pls find the images attached
It looks like a gamma issue, indeed.
Convert all bitmap loaders to VRayHDRI (right-mouse menu), and then change their color space to sRGB.
Render after resetting the V-Ray settings, and it should look right.
