are there some infos or examples on how to use?
thx!
Stefan
thx!
Stefan
ok i think i expected it wrong. it works for me on open edges, but not on edges within an object, like a grease or corner f a cube etc.
would it be possible to add support for an option to also edges not on open ends?
(i hoped it would solve the AO Iissue (with reacting to fine displacement)
The AO or the Round Edges already does the same thing for closed geometry (but does nothing on open geometry, which is where the new Edge shader comes in). Thanks!
well both have the issue (many times reported by me and others here) that they react on displacement in the material which is a real deal breaker for many effects.
so i hoped an edge based shader would do similar but ignore the displacement within a surface. (maybe optional like to use any edges starting with a certain phong angle)
p.s maybe this can be considered for future updates, if easy to add. it would make corona even more powerful and solve the old AO and curvature+displacement issue i think. best of course of Corona could find a way to fix these problems directly, so it works like v-ray dirt.
