Hi, I’m writing because I’m experiencing a display inconsistency between what I see in Corona’s VFB and in Photoshop.
I’ve attached some screenshots: the texture I adjusted in Photoshop (saved in sRGB) appears much redder when rendered than the original texture, but once the image is saved, it returns to the correct appearance.
For reference, I’m working on a calibrated EIZO CG2700X monitor using ColorNavigator.
I’d like to understand if I’m doing something wrong or where the issue might be.
thanks
