In houdini there is no burn value. So how do I adjust the blend between reinhard and linear color mapping mode?
And also the Colors Multiplier do have an effect on the rendering when reinhard is selected even though they shouldn’t as in the help specified.
We do not use the VFB for grading/tonemapping for now. Btw. are the settings of the VFB respected if you later render your images without buffering them to VFB?
It would be nice to know how the parameters in the rop in fact do affect the image since they apparently do different things then the help says.
>I’ll hide dark mult if Reinhard is selected and rename parameter to “Bright Mult. / Burn Value”
While doing that can you please double check.
The picture below is rendered with exponential color mapping. The region on top is rendered with reinhard “bright colors multiplier” set to zero. Which should blend 100% to exponential right? But the result looks different.
