Why is there no match between the preview ball and the texture?
Hello @alfonso_pennacchio , Thank you for reaching out. Could you please provide a bit more information so we can assist you further?
Cinema 4D version: 2023
V-Ray version: Update 2.4 (v6.20.04)
@alfonso_pennacchio
Thanks for the provided information. I’m unable to reproduce the issue using the same versions, so it would be helpful if you could share the simple scene I mentioned previously. If you’re unable to upload the scene, you could instead share screenshots of your material setup.
Note that the texture is darker than the preview
PREVIEW TEXTURE.rar (1.83 MB)
Thanks for the provided scene! It seems that the image’s color profile is causing the difference between the Texture and the Material Preview. An easy fix for this would be to add a V-Ray Bitmap in the texture section. By default, its RGB Primaries should be set to sRGB, which will display the correct preview.
Here is an example:
