Color Mix does not work properly with IR, if do some setting it shows like no glossiness, stop and start again IR then shows correct result.
File and video sent.
Thanks.
Thanks.
Thanks for the files. Internal note, added to wrike.
Update: scene was tested and is working for me in Windows. We will continue to investigate.
Remove Corona Mix and add texture direct, reflection works fine in IR.
