Color parity from Houdini to Maya and Vray
I have an asset that I am trying to translate from Houdini to Maya and render with Vray in Maya. The issue I am having is trying to match the look of Cd attribute data on geometry, instanced or otherwise, export the geo as alembic and/or USD and lookdev Vray materials.
I am not applying any color transform on the attribute on export.
On the Houdini side I am using Houdini 22.0.368, in the viewport I have sRGB - display set as display device and Un-tone-mapped as view transform and I get this result:
When I get the asset over to Maya, I load an alembic as a Vray Proxy, apply a VrayMtl with VrayUserColor to source the Cd attribute and channel that into diffuse color of the material. I render with Vray frame buffer, I have the same display device and view transform. I am using Maya 2024.2 and Vray 6 update 2.2 for Maya. This is what I see in the render using a diffuse render element:
If I add a VrayTexOCOI node between the UserColor and the material and set it to:
In: scene-linear Rec.709-sRGB
Out:ACEScg
it looks somewhat closer to what colors I see in Houdini, but I wouldn’t say I have parity between the two:
Please let me know if this is an issue of both programs using different ocio configs, or there is a certain setup I need to follow to get the colors I want from Houdini into maya and Vray? Maybe its an issue that got resolved with a more up to date version of Vray for Maya?
Thanks,
Goran
Can you post the scene or a repro?
Hi, @hsz this is a minimal project I was able to set up to showcase the issue. WeTransfer link for anyone needing to look into the issue Unique Download Link | WeTransfer
H22 uses ocio v2.5 - you need to use the same ocio config in both. I can’t remember what M 2024.2 ships with by default, but if you look at the raw data - it matches the values exactly (Cd) in this case, which at the of the day its the most important thing. The VP wont give you an accurate color by any means, they also both uses different tech for their VP, but anyhow you should never trust the VP in 3D. If you render and save them as .exr then apply the same config in comp they look the same.
