Color Picker window issue
In my work, I do not use the CMYK color space. I hide it as unnecessary and try to reduce the Color Picker window (1). But with each next opening of the Color Picker window, everything returns to its original appearance and size (2). Is there any way to save these parameters in the form I need?
I can confirm that is the same here. Corona 8 has introduced a bunch of UI problems in my opinion.
It would be great to have dialogs remember size, positions, and settings. There is a lot of clickign goign on atm
to have things the way you need them.
Can confirm this too. It’s very annoying.
Acknowledged.
I’m also having problems with the color picker interface taking several seconds to open every time I need to adjust a color. It takes more than 4 seconds!!! It’s too slow
Should I use a different thread for reporting this?
I also have a delay when opening the color picker window to adjust the color.
Hi, we’ve already identified a possible cause for this and it seems it’s a 3dsMax bug, we’ve also notified Autodesk about it so hopefully it will be addressed, or a different alternative will be found.
(Report ID=CRMAX-1351)
Thanks for the feedback everyone, I am reporting this, highly likely it will be improved.
(Report ID=CRMAX-1564)
It’s the same with point sample size. It would be nice if you could fix it as well, especially since i reported it with the old colour picker ages ago ;]
Noted :).
Hello. I also notice that the color temperature value is also not saved. After closing/opening the window, the value becomes 1700K
