Is there a color splitter node in Corona? I.e. take an input from an image and split it into RGB?
Hi there,
If I understand correctly, you should be able to do this by creating 3 colour correct shaders and enable the curves, from there you can use the RGB settings to determine the output. I hope this helps.
