Color Swatch doesn't work in Light Lister when the Corona Improved Picker is employed
If you prefer to use Corona’s “Corona Improved Picker” for your Color Selector (Customise>Preferences>General>Color Selector), then when you try to change the color of a light through the swatch on VRay Light Lister it doesn’t take affect.
If you do this via the Modify panel, you can change the color of the light this way (using Corona’s Improved Picker) no problem.
It’s only through the Light-Lister that the problem seems to exist.
Plus you also need to refresh the Light Lister (when using Corona’s Color Picker) - when using the standard 3DS Max Color Picker, the Color Swatches change dynamically (in both the Lister and the Modify panel) with no refreshing necessary.
I cannot replicate the issue when color is changed from V-Ray Light Lister, it’s properly updated!
http://ftp.chaosgroup.com/support/screenshots/2019-03-14\_15-40-06.gif
The second issue when color is changed from Modify panel is reproducible here but it also happens with native 3dsMax Listerner and lights:
http://ftp.chaosgroup.com/support/screenshots/2019-03-14\_15-41-21.gif
I’m using Corona Renderer 3 (hotfix 1) / V-Ray Next for 3ds Max, update 1.1 / 3dsMax 2019
Maybe it’s better to report this to Corona’s Forums cause it doesn’t seem to be related to V-Ray.
