hello..i’m not sure if this suppose to happen or not. The ground for the grass looks fine even in the distance..but the small plants on the other lose their color (washed out) the further they are from the camera.
The pic with the trees I have reflection turned and trans. on.
The pic without I turned everything off except for the opacity map and diffuse map for the plants.
The pic with only grass renders perfectly fine no washing out of colors occurring at distance.
I was dumb..I forgot that the leaves r not simple planes but meshes (growfx)So I actually don’t need alpha maps at all, cause I make sure that the bitmap cover the leaves completely by using the offset and tiling option in diffuse slot. But the problem still remain..
Well my leaves images always have a background color that matches the leaves color somehow, but is in TGA format. Does corona bitmap support TGA?
I turned off leaves diffuse and it rendered fine with just a plain color
double post my bad..Found the problem!! I convert my diffuse tga leaves to jpeg and it worked fine!! I guess corona bitmap loader doesnt support Targa images??
