Color
Hi-
I am having the hardest time trying to get colors correct. As you can see my colors are totally different from my color picker and v-ray, yet I am using the same numbers.
http://www.sendspace.com/pro/dl/ujei1h
I do have MAX’s gamma set to 2.2 as well.
I guess it’s because in MAX gamma setting pannel you have “Affect Color Selector” enabled so the values you put in the MAX color selector dialog have a 2.2 gamma applied.
To get the same color than in ColorPic you can try to change VRayColor Gamma Correction settings:
- gamma correction → specify
- gamma value → 2.2
And then reenter the color values (48,43, 25)
