ColorCorrenct and bitmap output curve don't work on Bump?
I tryed make a bitmap texture loaded a bump bitmap, turn on ‘Enable Color Map’ in Output , modified the Mono curve, but it doesnt work for bump.
and i tryed connect ‘Color Correction’ node ,modifed bright and contrast value, it’s useless too.
color map in bitmap output , and color correction node , they worked well on Diffusemap ,Roughness , Self-Illum and all maps but Bump. ..
3dsmax 2019 and vray5 update2 cpu renderer (vray5GPU works well)
Is this normal?
Thanks!8)
it is to be expected.
It is normal; you can use VRayColor2Bump to convert the color output of a texture to bump; then you can apply color corrections, curves etc on the input of VRayColor2Bump and they will be taken into account. This is what V-Ray GPU does internally.
YES! VRayColor2Bump did it.
Thank you Vlado !!
