Colour from object display color
Hi There,
I’m trying to convert a redshift scene to Corona. One of the things I need to do is colour up a ton of instances based on their display colour. Is there some way I can reference this in Corona? Set Driver - Driven doesn’t work because it only picks up the display colour of the original object and not the instances. I need one shader that ‘sees’ the display colour. This is easy in Redshift as it has a node for it but I can’t figure out if its possible in Corona.
Thanks for any help
Hi, did you try to use the C4D’s Display Color shader? You can find it in the “Surfaces” menu in the shader creation menu.
I just tried this with instances (both normal and render-instances) and it works with them too.
Brilliant! Thanks for this. I didn’t even realise there was a display colour shader! I’ve been using Cinema for 5 years too!
In Corona for Max there is a “Corona Data” map, which has an option to color objects based on their wire color (Max equivalent of C4D’s display color I guess).
Is there a Corona Data map in C4D?
