Colour Management and Vray
However, I’d be happy for now if Vray would allow embedding the monitor icc profile into the output bitmaps.
I’m converting all input bitmaps to sRGB, using Adobe Bridge, to avoid color shifts.
Here is your contradiction… input is sRGB, therefore the output is also sRGB, and should be treated that way. If you are visually pleased it’s ok, but it’s NOT correct to assign the monitor profile to the image. It should be assigned the sRGB profile and _converted_ to the monitor profile for viewing.
