Combine Displacement and Normal maps
Status: planned
Hi
I think it will make our materials much more realistic if we had the option to add
Displacement and Normal maps at the same time
right now we have to choose between them
Submitted on AHA Ideas by tatdesign96 (ENSCAPE-I-1135).
requested to be able to use displacement and bump maps simultaneously.
Submitted on AHA Ideas by anh_1751010002.
Allow normal and displacement maps to both be used at the same time. Each is designed to show a different type of detail and would increase the realism of images significantly. This already works in the enscape engine as there is a method to merge textures in Photoshop however it is difficult to control the effect.
Submitted on AHA Ideas by ba.gilchrist.
Enscape will allow you to use either Normal or Displacement texture maps, but not both at the same time. These textures of serve different functions where displacement modifies the general shape properties at a rough level and Normal maps act to create a much finer level of detail on the surface. Having the option to use both at the same time would bring another level of realism to images.
Please allow for normal and displacement textures to be used together. Currently you have to choose between one of the other. To achieve full realism, both should be used as normal maps provide the fine layer of detail and displacement modifies the geometry in a more macro manner.
AHA Ideas status: Planned.
Set during AHA Ideas to Discourse migration.
