I’m wondering has anybody noticed a slight difference in value when they combine, for example, direct, indirect and reflection passes when compared to the beauty pass?
The change is very slight, but it’s there.
Cheers
Cheers
Cheers for the quick response ![]()
Yes, I had a value of 1.3 in the highlight compression.
So what’s the usual practice for this? I was using that setting as it gave me a lovely balanced look in my lighting.
Would changing the exposure setting give similar results that don’t quite match also? Just curious.
Just do it in comp, there are several tools in the forum, two scripts for Fusion, one for Nuke I think, and After effects has it’s own HDR Compression tool.
Cheers!
Cheers, do you have a link to the scripts? Would’t mind seeing them thanks
Cheers, you are awfully nice!
Cheers!
