There was a problem in enabling V-ray toolbar in Revit 2019. Attached herewith error massage and the login file. Could you please help me on this issue?
Thanks & Regards,
Dinalie
VRayForRevit-20210907T060715.txt (69.9 KB)
Thanks & Regards,
Dinalie
Dear dinalie_peiris, hello.
In order to be more helpful, please define the following:
Waiting for your answer.
TS
Here are the answers for your questions.
Thanks,
Dinalie
Thank you, please check again the last point.
After opening VRayForRevitReleaseNotes.html it should look like this.
Another option is to open a blank project, Enable V-Ray, go to V-Ray > Help > About and send us a screenshot of the window.
Exact V-Ray version is Release Notes - V-Ray | Revit - Version V-Ray for Revit 5.10.08
Thanks,
Dinalie
Hello again, Dinalie!
In conclusion, you could try updating to out latest official build from here.
Unfortunately V-Ray 5 System requirements include Windows 8.1 and 10, since Microsoft dropped the support for Windows 7 too (discussed also here).
Therefore some issues (like the described from you) may appear. Of course it is your decision to update Windows or not, but we have to inform you to keep this in mind.
Thanks for your support. May I know if I can changed my V-Ray licence for another PC which complies with all the system requirements.
Hello again, you could achieve it easily:
If you are experiencing any difficulties - contact us, we are here to help.
Dear josip_armicsponza, hello.
Thank you for the detailed information.
From the screenshot could be seen that the error message is different.
Since it is happening only in one specific project, will you be able to share it with us?
The best way is to use our contact form and paste the ticket number here thereafter.
I will explain what we need to investigate further.
Also please confirm is it a Workshared Project or is any cloud service used to work over it.
TS
It is collaborative model, but not workshared in cloud service. I have send detached model - I´ve tried run render in detahced model too, with the same error results.
Ticket number is 3770.
Thank you,
JAS
Got it, thank you!
