Command line render crashes on glare
When i render a highres image on our render farm (so a Maya command line render) it always crashes on the glare. When i look in the log file i see that the render is finished completely. Then it tries to calculate the glare and then it crashes.
Bad thing is that the render is not saved.
We allready have this issue a long time. So it was allready in earlier versions of vray and Maya.
When i render in the viewport in the same resolution all works fine.
Does it happen in a particular scene? Could you send it? Mention your Maya and V-Ray versions as well.
It does not happen in a particular scene. It happened in different scenes in the past 2 years. I think mostly when i render high res. But i did not test it that much.
At the moment i am using Maya 2024 with Vray 6 update 1.1
But before when we used Maya 2019 with a former version of vray it also happened.
