Irradiance Map without calculating prepasses will always generate flickering in the animation with moving objects. Activating Camera Path option will certainly make the animation smoother but it will not resolve the flickering even with high sampling/interpolation settings.
There are basically two ways to render animation with moving objects with V-Ray. One is Brute Force + Light Cache which is a bit slower but it will generate flicker free animations without any prepasses and the second one is Irradiance Map + Light Cache which is a bit faster but might require a bit of tweaking until you find the correct settings and it will also requires a pre-calculation.
This is in the to-do list and will be available for future versions but it is not developed yet.
