Really sorry… another Issue …
With VFB life rendering it works,
but with regular rendering VFB or PV :
Comp Tags on a Sphere Objects do not work.
If you convert the Object to Polygons the Problem is fixed.
best, Index
best, Index
Hello @index ,
Can you please elaborate on the issue? Is it that the sphere is not rendering when production rendering but it is rendering in interactive? If that is the case, please note that there is a known issue with the “Render perfect” option for the Sphere object (bug ID: VC4D-619). The current workaround to that would be to disable the option.
Please let me know if that helps. Thanks.
Tx, and yes, its the same issue… i am just testing conversions and report issues i find.
Did you see the post about the color thing?
