comping diffuse passes creates "halo" white edge error
I can email something to support for you guys to look at.
I did find a workaround that seems to fix it:
totalLight divided by diffuse = new Raw Light.
Note in the attached image that the resulting raw light looks markedly different from the raw light render pass.
Then I can use this to recreate the total light without the edge error:
new Raw light x diffuse = totalLight
and properly insert a color correct:
(new Raw light + CC) x diffuse = totalLight
This workaround seems to solve the issue, but it makes me suspect that there may be something off with the passes generated by vray. A least that is, the math appears to not be working back and forth with multiplying and dividing these, so there’s a “fly in the ointment” somewhere in there. I’ll send the scene so you guys can investigate.
