Hi.
I’m having a really annoying problem at the moment and im not sure if its a hardware or software issue. I just cant think of anything to solve it so I thought I would see if anyone else on here can help guide me in the right direction. posted in AREA but have not got a reply…
So basically my PC completely shuts down when I do certain things in 3DSMAX, the screens go black but the pc fans are still running/ motherboard is still on. No matter what I do I cant get it to start/shut down unless I press the hard restart button on the motherboard.
I originally thought it was a graphics card issue but I ran some benchmarks to test it on full load and its working fine. This is with Max 2019, and I have just installed 2018 and I have had the same issue.
example one, scrubbing the timeline with an animated noise modifier on an object.
example two, manually stopping a corona render frame buffer (only occassionally)
latest servce packs on both installs
new pc build- few weeks old
threadripper 2990wx
msi meg x399 creation (beta bios E7B92AMS.129) im going to try and go back to E7B92AMS.127
64gb flare x ram
msi duke 1080ti
windows 10 pro
New installs in the last weel
Corona 3
Grow FX
Marvolous Designer.
Event Viewer
critical- Event ID 41, Kernal-power
Administritive Events at time of crash
Event 10016, distributedCOM
1
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{D63B10C5-BB46-4990-A94F-E40B9D520160}
and APPID
{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
to the user DESKTOP-7L9ESE1\dowli SID (S-1-5-21-1880292377-3472211445-3926164720-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
2
The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
Windows.SecurityCenter.WscDataProtection
and APPID
Unavailable
to the user NT AUTHORITY\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Is there some sort of admin access issue with 3dsmax?
Any help would be really appreciated
Thanks!
