Compose with CShading_SourceColor
Hello guys,
There is some way to compose the beauty with the elements, but using the CShading_sourcecolor? If I use the CESSENTIAL passes, I can’t manipulate the shadows, and etc. What is the best way to do this?
if you do source color * raw lighting, you will get cessential for that BRDF component
Thanks Ondra, it’s working!
I got the beauty passe doing this:
source color * raw lighting + reflection + refraction + emission + translucency
It’s okay by here, the only problem is that the raw lighting is giving me the indirect light together, and not only the light, because this I’m not able to grading only the indirect light if I want.
you can revert the formula
lighting = source_color * raw
raw = lighting / source_color
i.e. raw_indirect = lighting_indirect / source
where lighting_indirect is (CESSENTIAL indirect pass
Thanks Ondra!!
