Composite Map BUG (Vray v2.00.02)
if I use a composite map in the bump channel to layer some maps. The opacity value of each layer (composite_screen.jpg) is ignored and always at 100%.
This happens only with V-Ray Advanced (vray_adv.jpg), the V-Ray RT result is correct (vray_rt.jpg).
I have attached a simple scene and the rendered images.
Scene.zip (73.7 KB)
Hm, I can’t seem to be able to reproduce this in 3ds Max 2011; if you have the scene, can you send it to me at vlado@chaosgroup.com ?
Of course, scene sent.
Hello Vlado,
were you able to reproduce this problem already?
