Composite render element in VFB doesn't working
Hi.
Using the last vray 5.10.01 build 30667, max 2020. and here is the result
With Update 1 when you add an element to composite - you start with black and not the RGB. If you want to add to the RGB - you have to add a render element layer with the RGB channel in it.
Yavor
Thanks Yavor.
Forgive me for my lack of understanding
Not how to do the first option nor the second option.
Is it possible to attach a small tutorial on how to perform the composition in update 1 in both cases?
Ah sorry I should’ve added a screen shot from the beginning:
You need to add the RGB color as the first layer (bottom up) - and then proceed in the same way you did before adding other elements.
Another option is to add the VRayBackToBeauty render element in Max - it will automatically add all the required elements and create a composite in the VFB.
Thanks Yavor.
Things are more understandable now
