Hi ![]()
How would you Composite SSS render element together with:
GI + lighting + specular + reflect + refract
Best Regards
Jacob Hansen
Hi ![]()
Best Regards
Jacob Hansen
You can just add it on top, with a plus or screen operation.
Georgi Zhekov
Can you show your render elements as well? What program are you using for compositing?
At the comp stage in AE you have to use “Add” mode instead of the “Screen” one. Probably this is the reason way you get different results.
Hi, ![]()
It doesn’t seem to work with ADD or SCREEN!
I have attach the files. Hope you/someone will try to give it a shot. ![]()
Files:
http://www.wireguruji.dk/vrayForum/VRayRenderElementsLWF.zip
Best regards
Jacob Hansen
I can confirm the comp differences between the results.
Would it be possible to send us the Maya file to investigate further? You can use our support mail (support@chaosgroup.com)
Thanks for trying ![]()
I have send a Maya scene to this mail(support@chaosgroup.com) for further investigation.
Best Regards
Jacob Hansen
Thank you for the scene.
The overall brightness difference between the comp and RGB image is because of the color mapping settings. You have to set the color mapping type to Linear multiply and revert the Dark/bright multiplier to their default values “1”.
This should fix part of the issue.
Now I’m going check what is the problem with the SSS material.
…Super! And thanks for looking into this.
The reason for using HSV exponential color mapping with Dark multiplier set to 1.500 is to prevent color burn
that the physical camera sometimes create. But i see… Maybe it is better to prevent that from happening in another way.
Looking forward to hear what the problem is with SSS material. ![]()
Best regards
Jacob Hansen
Hi again,
Do you have access to the V-ray for Maya nightly builds? We have some improvements there regarding the SSS compositing workflow and the comp result exactly matches the one from the beauty.
I do not think that I have access to V-ray for Maya nightly build!? I will be more then happy to get access to the V-ray for Maya nightly build.
Jacob Hansen
Thanks, I have sent you a reply via our ticket system with details about the nightly build access.
Just sent a mail to get access to the nightly build.
And thanks for looking into this for me ![]()
Best regards
Jacob Hansen
Is it the same thing with vray for 3dsmax? I have to composite ss2 element too but in max. Should I use the nightly?
It should work fine with the official Vray for 3DSMax build.
