Compression and playback suggestions for 720P animation
I’m coming to the end of an animation job which has beeen rendered and edited at 1080x720 (720P) resolution.
h.264 Quicktime the way to go?
What’s it going to be used for?
yes, but you have to keep an eye on (if you have any) the soft color fades, they may have some comprimation relicts. a *mov with JPEG 75% codec works nice but gets you quite big files. but dont get under the value of 75%.
if you find out something better let us (me) know.
I do my postwork in AfterEffects and export to a single Quicktime File with the PNG codec.
It’s a standard QuickTime codec, it’s lossless, much smaller then uncompressed and holds an alpha channel.
This is also the file that i upload to clients if they continue to work with my Animations.
When i need smaller files because i don’t have so much time to upload i use quicktime-PhotoJPG 95% Quality setting.
This is slightly lossy but not detectable with human eyes.
Quicktime PhotoJPG 95% is also the codes that the stock footage supplier Artbeats uses on all of their files.
If you just make a final version for playback that will not be changed anymore use h264.
But it’s difficult to get all the export settings right.
Take a look at the h264 wiki page to understand the basics.
The most important settings are bitrate, profile and levels if you go HD.
“Levels” is a limiter to make sure that h264 plays back smoothly on less powerful hardware.
If you set that to 5.1 you can even encode with film like resolutions like 4,096×2,048.
Personally I have never been able to get an h264 video to look correct, the gamma is always messed up whether I export out of AE, Premiere, or super. I gave up and purchased quicktime pro, opened the uncompressed quicktime, hit export and checked h264 and it came out perfect.
Having Quicktime Pro is essential. I always do some sort of adjustments to my animations through After Effects and render out an uncompressed .mov. Then I use Quicktime Pro to compress it into an h264. I still have problems with h264 being washed out. The solution can be found here -- VIDEO COPILOT | After Effects Tutorials, Plug-ins and Stock Footage for Post Production Professionals -- basically setting the Transparency to straight alpha in the video movie properties seems to do the trick!
Quicktime pro or windows media encoder are the two best I think. I use the windows media encoder x64 and find it is remarkably good, no washed out problems to fix and it’s a free download.
Thankyou all for your suggestions. I must say that the easiest way so far has been using Quicktime Pro on an uncompressed Quicktime file. In the past, I have always used Quicktime movies with jpeg compression: I will no doubt give that a go and compare the result.
I’ve found the same thing with the gamma/levels of the h.264 output. How annoying.
Totally. It’s amazing how everything I’ve tried exhibits the same behavior: is it adobe, quicktime, other??? None of the supposed “fixes” ever woked either to get the gamma correct either.
