IT is suggesting:
Threadripper 7970X (32 cores) with 256 GB RAM
Whatcha all think? Is the RAM overkill? Mainly stills and a few animations. What is the recommended video card nowadays? (Vantage)
IT is suggesting:
I’m still waiting for my NVidia RTX 5000 Blackwell card. Actually it has arrived to reseller, but it need to be installed with the designated fans. I have ordered the fans two months ago, but those have not yet arrived to our country. In the mean time, without fans, I have 79 dB sound volume whenever rendering something.
For a new system — and knowing the kind of projects you work with (I’ve tested a few) — I’d say 256 GB of RAM is a solid choice.
If you want to save some money, an alternative is to go with a Ryzen 9 9950X and 192 GB of RAM. You’d be roughly ~30% behind a Threadripper 7970X in performance, but you’d likely spend about half the money compared to that workstation configuration.
Best,
Muhammed
I thought you were mainly using your laptop?
I took on a Director’s role for a large firm in Dallas
They have two machines in-house, on loan from DELL for four months to test.
Intel 24 9 Ultra 24 core with an RTX 4000 24Gb card ($8000) and a Threadripper 9975 with 32 cores with a RTX 4000 20Gb card ($13000) - both 128Gb
I think I am leaning towards GPU rendering - thoughts?
Thoughts…after some wine and thinking back to using GPU for stuff…don’t do it ![]()
GPU in my experience throws just too many inconsistencies into the mix, making it a headache, unless you want to change your workflow to accomodate them.
That’s my experience, so others may have a different POV.
I am talking Vantage - Interior renderings take minutes. This company does design work for the largest home builders in the country, and they churn out dozens of renderings a day (for small houses, and the model is provided) with 8 people. My job is to increase quality and reduce render time, which is the only way I know how, which is something like Vantage.
Ok, if it’s vantage focused then yes, change the workflow and make it a fast pipeline that utilises GPU stuff at the cost of whatever finesse you lose from CPU I guess.
My guess is that any quality difference won’t matter, as we all know that the bottom line is eyes on the bottom line.
I haven’t seen any quality loss with Vanatge as of late. Earlier versions I did, but not these latest ones.
