Computer went to sleep while rendering
I was rendering in the latest Vantage, and the computer went to sleep halfway through the process. I had figured with the GPU at 100% it would prevent the computer from going to sleep. Is this an issue with Vantage not preventing the computer from sleeping or is it more in the power settings? This is a company computer, so our ability to edit power settings is restricted.
This issue was never brought up until now. As of 3.1.1 Vantage is not doing anything to tell the PC to go to sleep or to prevent it from doing so. It looks like we have to add a couple of lines of code to notify the OS to not do that.
It’s a windows thing. Set it to never sleep otherwise Vantage will pause until you wake up your machine. So a 5 min render can take forever.
We’ve added code that should prevent this from happening in the next update.
Windows 11 has gotten much more aggressive with forcing sleep. We had to set some registry flags to prevent it. The GUI settings for disabling sleep did not suffice. I can look up the specific flags if need be.
I’m using Awake from PowerToys.
Another workaround is going into the Windows Mobility center and turning on Presentation Mode before rendering.
Hi guys,
In the latest 3.2 release Vantage should prevent Windows entering sleep mode. If you haven’t downloaded it yet please give it a go and let us know if it works on your end.
Alexander
