Hey all!
Is it a normal amount of noise for Noise level 2.75%? (the limit was set to 3%)
I’ve turned off the denoise on purpose. It definitely makes things better, but isn’t it still too noisy for 2.75?
The main light source is white single map, but the noise is coming from two other sources as you can see it. Both native Coronian.
The window glass is removed from GI. No bump in any mats. The picture is from beauty pass (not a light mix). 3ds Max, Corona 4.0. None of the default settings were changed.
Am I doing something wrong, or it’s a normal noise amount for 3% without denoiser? Thnx!
