Consistent Lighting Elements // Vray Lights "Affect Reflection/Specular" does not change to old behaviour
we want to switch to the old behavior of composing the AOVs by turning off Consistent Lighting Elements.
Everything works fine besides: if you want to control the lights contribution by e.g. turning off “Affect Reflections”. This seems to not work at all, compared to “Before Vray Next”.
I attached a scene below
Maya 2018.3
V-Ray Next for Maya, update 2.2 version 4.30.02, revision 29994 from Apr 9 2020
Is it maybe already fixed or is it intended do behave so? Or is it a bug ;-)?
cheers
Dominik
Vray_next_test_scene.zip (13.6 KB)
Anyone any idea?
Are you saying toggling those attrs. off is having no effect? It works fine for me here -- Maya 2020.1 and Vray Next 4.30.01.
That’s an older version of Vray than yours so I suppose it’s possible a bug has been introduced…
Hi, yeah, exactly: when I turn off “Affect Reflections” nothing changes.
Maybe you are right - ill try a newer build.
tested with:
[2020/Jul/31|08:45:08] V-Ray: V-Ray Next for Maya, update 2.3 version 4.30.03, revision 30237 from Jul 24 2020, 02:00:57
No luck. Still the same
I think it has always worked this way, i.e. you will need to also turn off Affects Specular in order to remove reflections. I agree this doesn’t always make sense.
no, this behavior is intended with consistent lighting elements since Vray Next.
But can be switched to the old behavior by turning that off.
You can notice in the specular / reflection element, how indirect and direct reflections are handled either way.
With the new way (which is state of the art) from the point on you bring your glossiness away from 1.0, ireflections get treatened as indirect and go to the specular AOV.
But the button “Affect Reflections” seems to not respect the “consistent lighting elements” toggle.
Which could be a bug.
any ideas from Chaosgroup ??
Hey, sorry for the delay.
You have correctly noticed that the Specular render element holds the direct reflections and Reflection holds the indirect reflections in the scene. It has nothing to do with how glossy the material is (be it 1.0 or below 1.0). Your observation is correct and I believe that this was introduced with the Consistent Elements option in 4.30.01.
Can you tell me in a bit more detail what you need to achieve in your setup?
Hi Alex,
we were always happy to be able to disable unwanted reflections in certain parts of the geometry, if it was not possible to do it in a “real way”. e.g. Car Beauty Renderings.
That was in the days of Vray 3.6. No it seems not beeing possible, with consistent lighting elements on. BUT, even if we turn them off, “Afect Reflections” does not work. We still have reflections in the specular RE.
that was not the way in former times.
Hope that makes sense
cheers
Can you give me a specific example of what the setup is and what it achieves?
Is the goal to make a light completely not affect glossy reflections, but still affect non-glossy reflections?
Or is the goal to separate out glossy and non-glossy direct and indirect reflections to grade them in post?
Any scenes, example comps, illustrations, images or other will be very helpful.
Hi Alex,
I am sorry for being not precise enough.
I attached gifs and scenes for you.
My second gif is really bad quality, because of the file size restrictions, but I think you’ll get the point
LEFT: Vray_3.6.gif: This is the desired behavior (what we want to achieve) for Vray Next (but in this example it is done in Vray 3.6)
RIGHT: Vray_4.3.gif: This happens currently in Vray Next - but we want to have same behavior as seen in the previous example
Hope everything makes sense now
cheers
Dominik
maya_files.zip (19.4 KB)
Do you need to render in this setup directly? Alternatively, if you can separate the different light contributions in post and remove the unwanted ones as needed in post - would that be acceptable?
yes I think it could be possible.
We were only used to be able to get rid of the reflections, as it was handled by 3.6 and below. Now the “correct” interpretation and handling of reflections just involves new thinking.
cheers
Dominik
Having a similar thing.. Vray 5 - Maya 2020. Classic blend material carpaint. Vray Material for base and a second for clearcoat. As soon as I add a small amount of glossiness into the shader the vray lights affect reflections no longer works properly.
This I am hoping is a bug! As without this control I will not be able to use Vray 5 on automotive jobs… well any job that requires this specular vs reflection separation
I posted this before I found this thread.
Did this problem ever get fixed? This is the reason why we never upgraded to Vray 5. I still have the problem with Vray Next.
I’ve been working the same way in Vray for years as well, automotive and the same type of blend materials for paint you described. Dome 1 affect diff/spec and dome 2 affect refl. Just recently started to use Vray 5 and was disappointed they changed this behavior with the domes. I also am in a workflow that used the older version render elements instead of putting indirect reflections in the Refl RE and direct reflections in the Spec RE. Turning off consistent render elements does nothing. But it turns out if you disable adaptive dome on you dome lights, this should fix the issues with both problems you’re having.
Ok, seems this still doesn’t actually work. It breaks as soon as you add some reflection glossy in your materials. After a co-worker told me the fix to revert back with the above steps, when I actually used it on a project I found out it doesn’t actually work. Had a few others test on a simple scene and confirm that it actually doesn’t work. So the last version I have personally used that I know turning off consistent lighting elements worked, was Vray Next. This is really a hurdle in the automotive world where I’m at because we all have workflows/pipelines that depend on getting the render elements the old way. More so in the lighting process. To turn off affect reflections on a light to add spec only or the opposite, add some reflections on some glossy trim pieces, there’s no longer a way to do this workflow that we’ve all relied on for many years. In Vray 5, there seems to be no way of doing this anymore.
It does state in the documentation turning this off will render as it did before. Hard to tell if it actually does but there is definitely a bug with lights if so in Vray 5 specifically. I can’t have a light affect the reflection if I specify only reflection on it or spec if I only checkbox affect spec. Everything a light contributes goes in spec and nothing else. Reflection checkbox, as stated by others, does not work anymore. From the comments, Chaos seems to not understand the issue? Sure trying to split it out in post could work but seems it still won’t get what I had in version before Vray 5. For instance, if I have a light with a gradient ramp I want to add a nice reflective gradient across some glossy material, even with consistent off, it’s all controlled by the affect specular checkbox on that light. So when you look at the reflection RE, the reflection is in there and if you look at the spec RE, there is specular contribution. I don’t want any spec contribution but I have no choice anymore. Whereas before, I would just uncheck on the light diff and spec, those REs would never have any contribution from that light and I could just add that gradient reflection where I wanted. I guess my point is, sure maybe I could work around it, subtract it out but I don’t think I should have to as the Consistent Lighting checkbox states Vray will work as it did in Next and before.
Has anyone found a solution? Or will you guys at Chaos revert the function or turning off consistent lighting elements back to how it worked in Vray Next?
The solution for the HDRI seems to work (disable ‘Consistent lighting elements’, disable ‘Dome Adaptive’ on ALL dome lights in the scene). Unfortunately there doesn’t seem to be a way to get the ‘effect reflection’ option of a rectangle light to disable the reflection on fully glossy surfaces anymore. I use this a lot in automotive lighting to add bounce light to metallic paints without seeing the light source in the clearcoat. This is also a problem when using light selects, the ‘Direct illumination’ option also contains additional reflection information rather than just diffuse and specular contributions as it did in V-Ray Next. I understand the reason for the change but the compositing workaround doesn’t help when doing live lighting sessions with photographers, this is a big tool to be missing from my workflow.
