Constant crashes when using Corona via Parsec
I’m doing remote work for a while, and we’re using Parsec to access our local machines. I’ve been mainly working with Vray and never had any issues. Now that we are working with Corona, I’m having constant crashes a few seconds after having the IPR enabled, making it impossible to work right now!
At first i thought it had somewhat to do with the Nvidia AI Denoiser (since Parsec is from Nvidia)… but even disabling it makes max crash. Tried doing a fresh install of another version of max, and same thing. Tried on another computer, same thing… only with Corona renderer.
Any ideas what it might be?
Very urgent, since we can’t work with Corona remotely right now unless we use another streaming software (which are way worse and laggy).
Are you accessing some physical computers remotely, or are they some kind of virtual instances?
If they are physical computers, are you able to run a successful rendering locally on them? (just Max+Corona without Parsec or any other remote desktop app)
I would also advise this as the 1st step:
Please try removing the licensing files as instructed in point A.3 here:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000015667
Please let me know if that helped.
We are using parsec too, but 0 problems so far regarding that ..
