Constant stream of underwater bubbles
Is there a way to use Phoenix to create a bunch of bubbles that flat upwards…meshing together in a similar way to how blobmesh works? So, basically not just simple spheres.
You can emit foam underwater - check the Loop bubbles scene here - Chaos Docs
Then you can right-click and from the PhoenixFD Export Particles menu you can export the Foam to PRT. Then you can load the PRT with Frost and adjust your mesh.
Ivaylo gave me the setup in this thread a couple years ago, I have not revisited it. Not sure if will work now with flip.
Maybe you mean something like this: Phoenix FD - Underwater Bubble Walkthrough
Thanks for the links. I’m sure I can work something out with than info.
