im currently rendering with different chairs, but they always seem to somehow blend into the picture. For a nice render’s sake, should i put some carpet bellow them? make some more opening in that part? (it seems too dark anyway) reduce the reflection on the staircase wood material (its the same as on the bench in front of the window). Ill definitly put some slim pillows on that bench maybe thatll help.
i think that it can be found on www.suurland.com as a giveaway, but im not 100% sure because i have it for a while.
About the rest of the textures, they are mostly from osmosis’s tutorial, and too bad they are so low res i really like that concrete panel texture…
it’s possible to cantilever the stairs from the wall (I would use steel myself) but then your wall would show that the stairs are imbedded or there would be couplings of some sort holding the stair to the wall.
as it is the wall was built and then the stairs are placed against it. which makes them float.
To help the stairs from failing your hand rail could connect to each tread and then the stairs could hang.
