Control Emissive Material texture via Xpresso/User Data
Hello!
I am working on an Xpresso rig where I need to end user to drop a texture into my user data slot and this would become the texture for an emissive texture on a plane in the scene. I have the setup working correctly in Redshift, so I know My methodology is working overall. It’s all simple set driver/driven stuff.
With Corona, when I drag the material into the Xpresso window, there is no port for Emission Texture, only Color (& Color R,G,B) - am I missing something? Connecting to the color port isn’t working and when I try to manually drag the texture field from attributes to the node, it lets me make a Texture port, but it won’t let me connect anything to it. Weirdly, I can choose Texture from the OUTPUT side of the node but that does nothing to help me.
Any thoughts here? I realize this is an obscure request.
Thanks,
e.
Here is a sample scene that shows a basic version of the setup. Thanks in advance for any ideas.
Corona_texture_xpresso_v01.c4d (175 KB)
here u are :wink:
Corona_texture_xpresso_v01-tuami.c4d (198 KB)
Brilliant! That works perfect - thank you!
